"].join(""),o=null,r={display:"block",position:"absolute",left:"-9999px",top:"0",width:"2px",height:"auto",border:"0"};e.src="about:blank",e.id=i,e.name=i,e.width="728",e.height="90",e.frameBorder="0",e.allowtransparency="1",e.scrolling="no",e.className="advblock AdSense",n.body.appendChild(e);for(var l in r)e.style[l]=r[l];o=e.contentWindow.document,o.open(),o.write(t),o.close()}},d=function(e){var t=["aolbuild","baidu","bingbot","bingpreview","msnbot","duckduckgo","adsbot-google","googlebot","mediapartners-google","teoma","slurp","yandex","bot","spider","crawl"],n=null;for(var o in t)if(n=new RegExp(t[o]),n.test(e))return!0;return!1};t.adregain_wall=!0,t.addEventListener?t.addEventListener("load",r,!1):t.attachEvent&&t.attachEvent("onload",r),t[a]=function(e){function t(e,t,n,o){"insertRule"in e?e.insertRule(t+"{"+n+"}",o):"addRule"in e&&e.addRule(t,n,o)}if(e)try{var n=2e4,a=o(),i=o(),r=function(){var e=document.createElement("style");return e.appendChild(document.createTextNode("")),document.head.appendChild(e),e.sheet}(),d={isArray:function(e){return"[object Array]"===Object.prototype.toString.call(e)},make:function(e){if(!this.isArray(e))return this.make.call(this,Array.prototype.slice.call(arguments));var t=e[0],n=e[1],o=document.createElement(t),a=1;if("object"==typeof n&&null!==n&&!this.isArray(n)){for(var i in n)o[i]=n[i];a=2}for(var r=a;r div","padding:10% 10% 10% 20%;text-align:left",2),t(r,"#"+a+" > div:before",s.sort(function(){return.5-Math.random()}).join(";"),3);var p=d.make("div",["div",{id:a},["div","\u0423\u0432\u0430\u0436\u0430\u0435\u043c\u044b\u0439 \u043f\u043e\u043b\u044c\u0437\u043e\u0432\u0430\u0442\u0435\u043b\u044c! \u041d\u0430\u043f\u043e\u043c\u0438\u043d\u0430\u0435\u043c \u0432\u0430\u043c, \u0447\u0442\u043e \u043d\u0435\u043e\u0431\u0445\u043e\u0434\u0438\u043c\u043e \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u0442\u044c \u043f\u043b\u0430\u0433\u0438\u043d AdBlock \u0432 \u0432\u0430\u0448\u0435\u043c \u0431\u0440\u0430\u0443\u0437\u0435\u0440\u0435, \u0438\u043b\u0438 \u0434\u043e\u0431\u0430\u0432\u0438\u0442\u044c \u043d\u0430\u0448 \u0441\u0430\u0439\u0442 \u0432 \u0441\u043f\u0438\u0441\u043e\u043a \u0438\u0441\u043a\u043b\u044e\u0447\u0435\u043d\u0438\u0439 (\u0431\u0435\u043b\u044b\u0439 \u0441\u043f\u0438\u0441\u043e\u043a). \u0412 \u043f\u0440\u043e\u0442\u0438\u0432\u043d\u043e\u043c \u0441\u043b\u0443\u0447\u0430\u0435 \u043f\u0440\u043e\u0441\u043c\u043e\u0442\u0440 \u0441\u0430\u0439\u0442\u0430 \u043f\u0440\u043e\u0441\u0442\u043e \u043d\u0435\u0432\u043e\u0437\u043c\u043e\u0436\u0435\u043d. \u0421\u043f\u0430\u0441\u0438\u0431\u043e."],["span",{id:i},"Ok, \u042f \u043e\u0442\u043a\u043b\u044e\u0447\u0438\u043b \u0431\u043b\u043e\u043a\u0438\u0440\u043e\u0432\u043a\u0443!"]],"");n=1e3>n?200:n,"undefined"!=typeof window.localStorage&&null===window.localStorage.getItem("regainShow")&&window.localStorage.setItem("regainShow",0),setTimeout(function(){var e=document.body;e.innerHTML="",e.appendChild(p),p=document.getElementById(a);var n=Math.max(window.innerHeight,document.documentElement.clientHeight,document.body.clientHeight)/2,o=n-p.offsetHeight/2-100;document.getElementById(i).onclick=function(){window.location.reload(!0)},t(r,"body","background:#eee",4),t(r,"body > div","width:100%;max-width:650px;margin:"+(o>0?o:50)+"px auto 0;",5)},n)}catch(u){throw u}}}).call(this,"95fb86ebf0e68bd6f9bf3a499ac96ff8-798-1598425629");
09.09.2018 06:14 | Electric House 99.4
Подборка отличных ТОП-статей по стабилизаторам напряженияПодборка отличных ТОП-статей по стабилизаторам напряжения
На сегодняшний день подобная техника все больше набирает популярность, их приобретают не только промышленные компании, различные мастерские и офисы, но и владельцы квартир и загородных участков. В зависимости от предполагаемого источника нагрузки они делятся на однофазные и трехфазные агрегаты.
Стабилизатор напряжения представляет собой релейные, тиристорные (симисторные), инверторные или электромеханические устройства, которые предназначены для выравнивания напряжения сети в автоматическом режиме при любых его отклонениях от нормы. Это могут быть скачки, провалы или перепады питания в большую или меньшую сторону.
Для обычной бытовой электросети нормальным значением является 220/230 Вольт, а для промышленной трехфазной 380/400 Вольт. Именно стабилизирующие аппараты (стабилизаторы напряжения) обеспечивают правильное и надежное питание и предохраняют всю технику, которая к ней подключена, от разнообразных поломок. На российском рынке представлено большое количество вариантов стабилизирующий устройств.
Один трехфазный стабилизатор или три однофазных?
voltron-rsn-8000h.jpg Покупка мощного стабилизатора напряжения – это ответственный шаг. Стоит такая техника немало, а отдавать большие деньги за то, что может не подойти, никто не захочет. Надо все предусмотреть заранее. В особенности это касается фазности и компоновки стабилизатора. На рынке в большом количестве представлены как однофазные, так и трехфазные стабилизаторы. Правило выбора простое: если в дом заведены 3 фазы, нужен «трехфазник», если одна – однофазная модель... Подробнее >>
Зачем нужен стабилизатор напряжения?
voltron-rsn-8000h.jpg Качество электроэнергии в сетях, хоть и регламентируется по ГОСТ 13109-97, но на практике почти всегда не соотвествует требованиям государственного стандарта. В реальной жизни мы наблюдаем повышенное или пониженное напряжение в сети электропитания, резкие скачки напряжения, высоковольтные импульсы, колебание напряжения, высокочастотные помехи и т.п. Все эти дефекты отрицательно сказываются на... Подробнее >>
Как правильно выбрать и подключить стабилизатор напряжения?
voltron-rsn-8000h.jpg Выбирая стабилизатор для дома, надо правильно выбрать его мощность. Для этого необходимо рассчитать сумму мощностей стационарных приборов, которые впоследствии будут подключены к нему, и прибавить 20% для запаса. Типы стабилизаторов напряжения. Таблица для определения общей мощности домашних или дачных приборов. Схема подключения стабилизатора в однофазной сети. Схема подключения стабилизатора в трехфазной сети... Подробнее >>
Электромеханические стабилизаторы напряжения
voltron-rsn-8000h.jpg Электромеханический стабилизатор напряжения представляет собой вольтодобавочный трансформатор с поворотным щеточным механизмом, который управляется специальным контроллером с помощью сервопривода. Регулировка выходного напряжения осуществляется за счет перемещения токосъемной щетки по контактной поверхности трансформатора, при этом плавно изменяется коэффициент трансформации (понижается или повышается)... Подробнее >>
Как правильно выбрать стабилизатор напряжения для дома
voltron-rsn-8000h.jpg В наше время на рынке представлено большое количество разновидностей стабилизаторов напряжения. Электронные, электромеханические, релейные, гибридные и тиристорные. Так какой из них лучше... Подробнее >>
Инверторные стабилизаторы напряжения — преимущества и недостатки
voltron-rsn-8000h.jpg Инверторные стабилизаторы напряжения постепенно выходят на первое место по популярности. Они очень надёжны, компактны, обеспечивают идеальные характеристики выходного напряжения и не имеют механических деталей. Его еще называют стабилизатором двойного преобразования. Звание лучшего он заслуживает за то, что может подавать ток, который характеризуется одной и той же частотой, стабильным напряжением... Подробнее >>
Калькулятор расчёта мощности для подбора стабилизатора напряжения
voltron-rsn-8000h.jpg Предлагаем воспользоваться нашим on-line калькулятором для расчёта и определения мощности стабилизатора напряжения. Уделите немного времени... Подробнее >>
Калькулятор расчета сечения кабелей и проводов по мощности и току
voltron-rsn-8000h.jpg Калькулятор позволяет рассчитать сечение токоведущих жил электрических проводов и кабелей по электрической мощности. Электрические кабели и провода – основа энергетической системы, если они подобраны неправильно, это сулит множество неприятностей... Подробнее >>
Стабилизатор напряжения для майнинг-фермы
voltron-rsn-8000h.jpg Заработок в интернете путем майнинга (добычи) криптовалюты известен достаточно давно, но интерес к этой теме не ослабевает. О майнинге регулярно говорят в новостях и пишут в газетах. Буквально на днях пресс-служба правительства Ленобласти презентовала открытие в Киришах крупнейшего в России майнинг-центр мощностью 20 мВт. Объем инвестиций в проект составил порядка 500 млн рублей... Подробнее >>
FAQ - Ответы на часто задаваемые вопросы по стабилизаторам напряжения
voltron-rsn-8000h.jpg Большинство современной бытовой техники, электроприборов, электроинструмента или специального оборудования имеет в своём техпаспорте прописанную норму качества потребляемого напряжения. К сожалению, Российские электросети далеки по состоянию от идеальных. В городе, конечно, ближе к норме, но и здесь бывают случаи, когда чувствительная аппаратура требует отсутствия даже самых минимальных перепадов в сети... Подробнее >>
Теги: стабилизатор напряжения статьи
Copyright © Electric House. 2005 - 2020. Москва. Россия. При использовании материалов обязательна ссылка на: Тех.поддержка | Реклама на сайте
